kpi hotspot <label>
Define hotspot finder search criteria and label options.
kpi hotspot <label> createentity <set|notes|measures>
kpi hotspot <label> criteria <name>=<value>
kpi hotspot <label> export <filepath>
kpi hotspot <label> findhotspots
kpi hotspot <label> options <note|view|default> <name>=<value>
kpi hotspot <label> review
Arguments
- createentity
- After reviewing the hotspot results, you can save them as one of the following:
- criteria
- Define/review the following hotspot finder search criteria:
- export
- Export and save the displayed rows and columns of the hotspot search results to a CSV file.
- findhotspots
- Find hotspots in the model.
- options
- Define the following options for note and view:
- resulttable
- hideranks
- Select the range of ranked results to hide.
- showranks
- Select the range of ranked results to display.
- review
- Review the hotspot search results.
Examples
kpi hotspot "Hotspot Query 1" criteria loadcase=current filtertype=greaterthan lowervalue=0 minimumdistance=75.000000 numberofhotspottype=top numberofhotpottopvalue=5
kpi hotspot "Hotspot Query 1" findhotspots
kpi hotspot "Hotspot Query 1" review
kpi hotspot "Hotspot Query 1" export C:/Users/User1/Documents/result.csv
kpi hotspot "Hotspot Query 1" createentity set
kpi hotspot "Hotspot Query 1" criteria advancedsimulationlist = "1 2,1 7"
kpi hotspot "Hotspot Query 1" options resulttable showranks 1,10-11,2-9
