result iso display
HyperView - MultiCoreChanges the value display.
result iso display <name1>=<value1>
Argument
- <name1>=<value1>
- The name=value data name and/or attribute pairs that define the relevant
data. For attributes, this can be either the attribute name or ID.
- currentvalue=<value>
- The current iso value.
- incrementby=<increment>
- Enter a value to move the iso value by this amount.
- displayvalues=<above/below>
- above - Updates the graphics display so that all elements with result values above the current iso surface level (currentvalue) are displayed (unmasked) based on their display attributes.
- usecolor=<true/false>
- Select true to apply a color to the vector.
- color=<color>
- Select a color from the list or the color palette or enter RGB values to define the color.
Examples
result iso display usecolor=true
result iso display color Cyan
result iso display currentvalue=5
