result iso plot
HyperView - MultiCorePlots the iso data type results.
result iso plot <name>
Argument
- <name>
- The name of the iso results to plot.
result iso plot "Stress, Analysis System"
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
HyperView - MultiCoreLoad and unload animations.
HyperView - MultiCoreCancels all currently loading results.
HyperView - MultiCoreCreate and manage iso plots.
HyperView - MultiCoreClears the iso plot and returns the model to its original state.
HyperView - MultiCoreChanges the value display.
HyperView - MultiCoreClears the iso plot from the graphics window.
HyperView - MultiCoreControl the iso value displayed on the screen incrementally.
HyperView - MultiCoreLoad the iso data type.
HyperView - MultiCoreDisplays the current iso plot in the modeling window.
HyperView - MultiCoreCreate and manage contour plots.
Set the current simulation.
Makes a subcase current.
HyperView - MultiCoreCreate and manage tensor plots.
HyperView - MultiCoreCreate and manage vector plots.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
