result scalar delete
HyperView - MultiCoreDeletes the scalar data type.
result scalar delete all
result scalar delete <name>
Arguments
- all
- Delete all defined scalar plots.
- <name>
- Delete a specific scalar plot.
result scalar delete allView new features for version 2023.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
HyperView - MultiCoreLoad and unload animations.
HyperView - MultiCoreCancels all currently loading results.
HyperView - MultiCoreCreate and manage iso plots.
HyperView - MultiCoreCreate and manage contour plots.
HyperView - MultiCoreClears the scalar plot.
HyperView - MultiCoreCreates a scalar datatype.
Turns on/off discrete colors in the contour plot.
HyperView - MultiCoreEdits the properties of a result scalar plot.
Clears the scalar plot from the modeling window.
Interpolates the contour colors from the undeformed shape, with a zero value, to the result variable reported from the solver.
Edits the contour plot's legend properties.
Defines the legend's maximum value.
Enables the legend's maximum value.
Enables the legend's minimum value.
Defines the legend's minimum value.
HyperView - MultiCoreLoads and plots the scalar data type.
The multiplier for scaling all the result values.
Enter a value that will affect the contour value, contour min/max, and the legend min/max.
HyperView - MultiCorePlots the scalar data type.
HyperView - MultiCoreRenames the scalar definition.
Displays the current scalar plot in the modeling window.
HyperView - MultiCoreUnloads a scalar data type.
Set the current simulation.
Makes a subcase current.
HyperView - MultiCoreCreate and manage tensor plots.
HyperView - MultiCoreCreate and manage vector plots.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
result scalar delete all© 2023 Altair Engineering, Inc. All Rights Reserved.
