result scalar interpolatecolor
Interpolates the contour colors from the undeformed shape, with a zero value, to the result variable reported from the solver.
result scalar interpolatecolor <true/false>
Arguments
- true
- true interpolates the contour colors from the undeformed shape, with a zero value, to the result variable reported from the solver.
- false
- The contour colors remain the same for all frames.
result scalar interpolatecolor true
