result vector legendmax
Defines the legend's maximum value.
result vector legendmax <value>
Arguments
- <value>
- Enter the legend's maximum value.
result vector legendmax 14View new features for version 2023.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
HyperView - MultiCoreLoad and unload animations.
HyperView - MultiCoreCancels all currently loading results.
HyperView - MultiCoreCreate and manage iso plots.
HyperView - MultiCoreCreate and manage contour plots.
Set the current simulation.
Makes a subcase current.
HyperView - MultiCoreCreate and manage tensor plots.
HyperView - MultiCoreCreate and manage vector plots.
Clears the vector plot.
Changes the vector color for the components or resultant by direction or value.
HyperView - MultiCoreCreates a vector data type.
HyperView - MultiCoreDeletes vectors from the model.
Changes the value display.
HyperView - MultiCoreEdits the vector data type.
Clears the vector plot from the modeling window.
Edits the vector plot legend properties.
Enables the legend's maximum value.
Defines the legend's minimum value.
Enables the legend's minimum value.
Loads and plots the vector data type.
The multiplier for scaling all the result values.
HyperView - MultiCorePlots the vector data type results.
HyperView - MultiCoreRenames the vector definition.
Vector plot section options.
Displays the current vector plot in the modeling window.
HyperView - MultiCoreUnloads a vector data type.
HyperView - MultiCoreUpdates a vector data type.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
result vector legendmax 14© 2023 Altair Engineering, Inc. All Rights Reserved.
