result vector load
Loads and plots the vector data type.
result vector load <name> <name1>=<value1>
Arguments
- <name>
- The name of the vector to edit.
- <name>=<value>
- The name=value data name and/or attribute pairs that define the relevant
data for the plot. For attributes, this can be either the attribute name
or ID.
- cornerdata=<true/false>
- If corner data is available, enter true to use the Use corner data option, which displays color bands by interpolating available corner results within each element.
- displayed=<true/false>
- true - Activate this option to load results only on the displayed entities.
- layer=<layer>
- The layer definition.
- layerfilter=<layerfilter id/layerfilter label?>
- Enter the filter ID and value to reduce the layer list.
- marked = <true/false>
- Enable/disabled marked elements.
- sset = <sset name>
- Enter a selection set name.
- system=<analysis/global/elemental/system name>
- Enter the coordinate system that will be used to plot the results.
- type =<typel>
- The result type.
- usetracking=<true/false>
- If a tracking system has been activated in the Tracking panel, enter true to transform and resolve the results in the activated tracking system.
result vector load type="Acceleration" system=analysis
result vector load type="Stress"
