result vector legendmaxenabled
Enables the legend's maximum value.
result vector legendmaxenabled <true/false>
Arguments
- <true/false>
- Enables/disables the legend's maximum value.
result vector legendmaxenabled trueView new features for version 2023.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Resets the legend for contour, vector, tensor, and iso based on the currently displayed parts.
Create and manage file sets for derived loadcases.
Create and manage iso plots.
Create and manage loadcases for derived loadcases.
Create and manage the contour plot.
Set the current simulation.
Makes a subcase current.
Create and manage tensor plots.
Create and manage vector plots.
Clears the vector plot.
Changes the vector color for the components or resultant by direction or value.
Changes the value display.
Clears the vector plot from the modeling window.
Edits the vector plot legend properties.
Defines the legend's maximum value.
Defines the legend's minimum value.
Enables the legend's minimum value.
Loads and plots the vector data type.
The multiplier for scaling all the result values.
Vector plot section options.
Displays the current vector plot in the modeling window.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
result vector legendmaxenabled true© 2023 Altair Engineering, Inc. All Rights Reserved.
