save animation
Save the current page as an animation file.
save animation page <filename> <name>=<value>
Arguments
- page
- Save the current page as an animation.
- <filename>
- Use the file browser to enter a filename and select a directory to save the file to.
- <name>=<value>
- If the following options are not displayed or given, the defaults values
will be used as described in config.
- <type>=<filetype>
- File type options include: AVI, AMF, GIF. For these file types, one file contains the entire animation.
- dimension
- Define as pixel or percent.
- width
- The image width.
- height
- The image height.
- quality
- For JPEG only. Enter a larger value for JPEG quality for larger files.
save animation page C:\WorkingDirectory\truck.aviComments
This command only works on the content of the active window.
