save model
Export the page as an H3D file.
save model h3d <filename> <name>=<value>
Arguments
- h3d
 - This option only works on the content of the active window.
 - <filename>
 - Use the file browser to enter a filename and select a directory to save the model file to.
 - <name>=<value>
 - If the following options are not displayed, the defaults values will be
                            used as described in config.
- allmodels
 - animation
 - compressionloss
 - compressoutput
 - entityattributes
 - html
 - includemaskedelements
 - includesets
 - previewimage
 - results
 - viewattributes
save model h3d C:\WorkingDirectory\truck.h3d
