scale deformed
Change the display of a deformed shape.
scale deformed <name>=<value>
Arguments
<name>=<value>
Specify the following parameters:
resulttype =<type>
Select a result type. The available result types are determined by the nodal vectors in the results file.
scale=<scale>
Scale options are: scalefactor, modelpercent, modelunits (modelunits only available for modal and linear static animation modes).
value=<value>
Enter a scaling value.
x=<x-value>/y=<y-value>/z=<z-value>
Specify different scale factors to different X, Y, and Z components of displacement.
system=<system>
System options: global, analysis, user.
complexfilter=<filter>
Select the complex filter that you want to use for viewing the deformation.
"complexfilter" is only for modal animations with complex results.
Specify Displacement as the result type::
scale deformed resulttype="Displacement"
