scale undeformed
Change the display of an undeformed shape.
scale undeformed <name>=<value>
Arguments
<name>=<value>
Specify the following parameters:
display=<display>
Select a display option:
none
None of the deformed shape is shown.
wireframe
Displays the undeformed shape as a wireframe.
edges
Displays the edges of the undeformed shape.
features
Displays feature lines on the undeformed shape.
colorby=<colorby>
Select a color option.
component
Default colors are automatically applied to the undeformed shape.
mesh
user
You can click the color button and select a different color from the color palette for the undeformed shape.
color= <RGB/label/value>
The color for the undeformed shape. Options include RGB, label, or value (only valid for colorby=user).
movewithtracking=<true/false>
true
The undeformed shape moves with the deformed shape, allowing you to compare the two. Only active if the tracking system is enabled.
Specify that none of the deformed shape is shown:
scale undeformed display=none
