sset add
Adds entities to a selection set.
sset add <name> all
sset add <name> component argument
sset add <name> displayed
sset add <name> element argument
sset add <name> marked
sset add <name> range
sset add <name> select
Arguments
- <name>
 - The name of the selection set. For example, Set6. Select
                        the set you want to add entities to. Options include:
- all
 - Add all entities to the set.
 - component
 - Add components to the set.
 - displayed
 - Add displayed entities to the selection set.
 - element
 - Add elements to the set.
 - marked
 - Add marked items to the set.
 - range
 - Add entities by ID.
 - select
 - Add selection to the set.
sset add Set6 component "BEAm: DRIVE-SHAFT"
