sset create
Creates an empty selection set.
sset create component <name>
sset create element <name>
sset create node <name>
sset create section <name>
Arguments
- component
 - Create an empty component set.
- <name>
 - The name of the component set.
 - element
 - Create an empty element set.
- <name>
 - The name of the element set.
 - node
 - Create an empty node set.
- <name>
 - The name of the node set.
 - section
 - Create an empty section set.
- <name>
 - The name of the section set.
sset create component Set_10
