rpti::item::externalobject
Interact with items of type externalobject.
Supported Property Names
-name -file -parent
All properties available can be passed via the "create" API or modified on an existing item via the "set" API.
rpti::item::externalobject create
Creates an item of type "externalobject".
For
Value: A full list of standard property names see Supported property name above.
Returns
The ID of the item or .tcl-error in case an error occurred during creation.
rpti::item::externalobject create -name "My Word Document" -file "example.h3d"
rpti::item::externalobject delete
Deletes the item with the specified ID.
-id
Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
Returns
1 for OK, .tcl-error in case of error.
rpti::item::externalobject delete -id $id
rpti::item::externalobject get
Queries the value of one property.
-id
For
Returns
The value of the specified property or .tcl-error in case of error.
rpti::item::externalobject get -id $id -property parent
rpti::item::externalobject getpropertyid
Queries ID of property.
-id
Value: Item ID.
-key
Value: Property key.
rpti::item::externalobject getpropertykeylist
Queries list of properties.
-id
Value: Item ID.
Returns
List of property keys for a particular item ID.
rpti::item::externalobject set
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
-id
For
Returns
rpti::item::externalobject set -id $id -name "My External Object" -file "c:/temp/example.h3d"
