rpti::item set
Sets one or multiple parameters to specified values.
rpti::item set
-id
Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
For
Value: A full list of standard property names see Supported property name above. Use rpti::item getpropertykeylist for list of dynamic properties.
Returns
1 for OK, .tcl-error in case of error.
ardi::item::text set -id $id -name "My Text Item" -value "Good monring, how are you today?"
rpti::item setattribute
Sets/update item attribute.
-id
Value: Item ID.
-name
Value: Attribute Name which is usually a string.
-value
Value: Attribute value.
Returns
1 if success, error message if failed.
rpti::item setrole
Set/update item role
rpti::item setrole
-id
Value: Item ID.
-name
Value: Role name which is usually a string.
-value
Value: Role value.
Returns
rpti::item setselection
Queries current selected item set using rpti::item setselection.
Returns
Selected item id.
