::hwp::GetPlotHeader
Gets a header handle of a plot client.
Tcl Query
This procedure implements minus options.
This procedure returns a header handle of HyperGraph.
If no page ID is requested, then it operates on the current/active page.
If no window ID is given, then it returns a plot header handle of the active window.
Mandatory Arguments
None.
Optional Arguments
-page "pageID"
The page ID of the requested page.
-window "windowID"
The window ID of the requested window.
Returns
Returns a header handle of a plot client.
set headerHandle [::hwp::GetPlotHeader -page 3 -window 2]
