::hwp::GetVerticalAxis
Gets an axis handle of a plot client.
Tcl Query
This procedure implements minus options.
This procedure returns a vertical axis handle of HyperGraph.
If no page ID is requested, then it operates on the current/active page.
If no window ID is given, then it returns a note handle of the active window.
If no axis ID specified, then the primary axis is returned.
Mandatory Arguments
None.
Optional Arguments
- -clientHandle "plot client handle"
- The handle (object reference to a plot client).
- -page "pageID"
- The page ID of the requested page.
- -window "windowID"
- The window ID of the requested window.
- -axis "axisID"
- The axis ID of the requested note.
Returns
Returns a vertical axis handle of a plot client.
set verticalAxisHandle [::hwp::GetVerticalAxis]
