mdlIDataMember IsConst
Determines whether the value of the current data member may or may not be modified.
mdlIDataMember_handle IsConst
MotionView Tcl Query
This command determines whether the value of the current data member may or may not be modified.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle myhandle P_Global_Origin.x
if { ![myhandle IsConst] } {
myhandle SetRawExpression "2+3"
myhandle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
Returns True if this data member may not be modified, or False if this data member may be modified.
