mdlIDataMember IsOverridden
Determines if the value has been modified.
mdlIDataMember_handle IsOverridden
MotionView Tcl Query
This command determines if the value has been modified.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle my_handle b_temp.mass
set body_mass [my_handle GetEvaluatedValue]
if { ![my_handle IsOverridden] } {
my_handle SetRawExpression [expr $body_mass +10.0]
my_handle Evaluate
myModelName Evaluate
my_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
Returns True if the value has been overridden, or False if the value has not been overridden.
