plt3DIPlane GetCrossSectionOnly
Returns the cross section only state.
plt3DIPlane_handle GetCrossSectionOnly
Tcl Query
- True
- The cross section is visible.
- False
- The cross section is not visible.
None.
Gets the plane’s base coordinate.
Returns the color of the plane.
Gets the current drag location for the plane.
Gets the maximum drag location for the plane.
Gets the minimum drag location for the plane.
Gets the plane’s enabled state.
Gets a handle to an hwIFont interface for the font of the plane's label.
Gets whether a plane is highlighted.
Gets the location of a plane's label.
Gets the plane’s orientation plane.
Sets the current drag location for the plane.
Returns the plane’s visibility state.
Reverses the current direction of the plane.
Sets the plane’s base coordinate.
Sets the plane’s color index.
Sets the cross section only state.
Sets the plane’s enabled state.
Sets whether the plane is highlighted.
Sets the location of a plane's label.
Sets the plane’s orientation plane.
Sets the plane’s visibility state.
Tcl Query
None.
