plt3DIPlane GetDMin
Gets the minimum drag location for the plane.
plt3DIPlane_handle GetDMin
Tcl Query
Returns the real value of the minimum drag location for the plane along its normal.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName GetPlaneHandle myPlaneName [myPlotName AddPlane]
myPlaneName GetDMin
None.
