plt3DIPlane SetD
Sets the current drag location for the plane.
plt3DIPlane_handle SetD location
Tcl Modify
location
The real value of the current drag location for the plane along its normal. The value must be between GetDMin and GetDMax.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName GetPlaneHandle myPlaneName [myPlotName AddPlane]
myPlaneName SetD 10.0
Success (0) or an error code.
