pltIAxis GetDisplayValue
Gets the display value when the real value is input.
pltIAxis_handle GetDisplayValue real_value
Tcl Query
This command gets the display value when the real value is input. This command only works properly when the axis is scaled in dB20 or dB10.
- real_value
- The real value that you want to get the corresponding display value of.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetVerticalAxisHandle yaxis 1;
yaxis GetDisplayValue 30;
Success (the display value) or an error message is returned.
Keywords
Tcl
Axis
Query
