pltIDatum GetAssociatedAxis
Gets the associated axis for the datum.
pltIDatum_handle GetAssociatedAxis
Tcl Query
If the datum is horizontal, the axis will be horizontal. If the datum is vertical, the axis will be vertical. Returns the index of the associated axis for the vector.
None.
