pltIDrawControl DrawFilledEllipse
Draws a filled ellipse.
pltIDrawControl_handle DrawFilledEllipse ulx, uly, lrx, lry, color
Tcl Modify
Returns 0 = HW_Success or 3 = HW_InvalidHandle.
- ulx
- X-coordinate of the upper left point of a rectangle into which the ellipse is inscribed.
- uly
- Y-coordinate of the upper left point of a rectangle into which the ellipse is inscribed.
- lrx
- X-coordinate of the lower right point of a rectangle into which the ellipse is inscribed.
- lry
- Y-coordinate of the lower right point of a rectangle into which the ellipse is inscribed.
- color
- The index of the color to be used (must be non-negative).
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName
myPageName GetWindowHandle myWindowName
myWindowName GetClientHandle myPlotName
myPlotName GetDrawControlHandle myDrawer
myDrawer DrawFilledEllipse -.5 1 .5 -1 2Errors
None.
