pltITitle GetColor
Gets the text color of the title.
pltITitle_handle GetColor
Tcl Query
Returns the index of the title's text color.
None.
Gets the text alignment for the title.
Gets the title’s context menu parameter.
Gets the expanded text of the title.
Gets the title’s position.
Gets a handle to an hwIFont interface for the primary font of the title.
Gets a handle to an hwIFont interface for the secondary font of the title.
Gets a handle to an hwIFont interface for the tertiary font of the title.
Gets the text of the title.
Gets whether the title is displayed or hidden.
Sets the text alignment for the title.
Sets the text color of the title.
Sets the text of the title.
Sets whether the title is displayed or hidden.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
