pltIVectorComplex GetNumberOfDataAttributes
Returns the number of attributes in the vector.
pltIVectorComplex_handle GetNumberOfDataAttributes
Tcl Query
None.
Adds a new empty attribute to the vector.
Gets a handle to a pltIAttribute interface for the specified attribute.
Removes the specified attribute from the vector.
Sets the associated axis for the vector.
Sets the component used by the vector.
Sets the datatype used by the vector.
Sets the mathematical expression of the vector.
Sets the filename of the data file referenced by the vector.
Sets whether the vector is frozen or not.
Sets the offset of the vector.
Sets the request used by the vector.
Sets the scale factor of the vector.
Sets the subcase for the vector.
Sets the type of the vector.
Sets the data values of the vector.
Tcl Query
None.
