txtITextEditor GetBackgroundColor
Returns the background color.
txtITextEditor_handle GetBackgroundColor
Tcl Query
Returns an integer indicating the background color.
None.
Clears the text editor.
Redraws the text editor.
Evaluates the raw text.
Returns the evaluation state of text client text.
Returns the evaluated text.
Gets a handle to the font.
Returns the foreground color.
Returns the name of the text file.
Returns the raw (unevaluated) text.
Loads the text from a file.
Refreshes all page areas with the text changes that have been made.
Saves the content of the text editor to a file.
Sets the background color.
Allows you to control the evaluation state of text client text.
Sets the foreground color.
Sets the raw (unevaulated) text.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
