txtITextEditor GetTextFileName
Returns the name of the text file.
txtITextEditor_handle GetTextFileName
Tcl Query
This command returns the name of the text file as a filepath, if the file has a name. If there is no file in the text editor, then nothing is returned. There may be text in the text editor that has not been saved as a file and therefore, would not have a filename.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle txt;
txt GetTextFileName;
Success (the filename [or nothing]) or an error message is returned.
Keywords
Tcl
TextView
Query
