txtITextEditor GetForegroundColor
Returns the foreground color.
txtITextEditor_handle GetForegroundColor
Tcl Query
Returns an integer indicating the foreground color.
Success (0) or an error code.
Clears the text editor.
Redraws the text editor.
Evaluates the raw text.
Returns the background color.
Returns the evaluation state of text client text.
Returns the evaluated text.
Gets a handle to the font.
Returns the name of the text file.
Returns the raw (unevaluated) text.
Loads the text from a file.
Refreshes all page areas with the text changes that have been made.
Saves the content of the text editor to a file.
Sets the background color.
Allows you to control the evaluation state of text client text.
Sets the foreground color.
Sets the raw (unevaulated) text.
Tcl Query
