Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print,
damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each
specific keywords.
Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available
in Radioss and use different contact treatments.
Block Format Keyword This law describes the Jones-Wilkins-Lee EOS for detonation products of high explosives. Optional afterburning modeling
is available.
Block Format Keyword This law describes the boundary conditions material in flow analysis (ALE or EULER). It is compatible for
2D and 3D analysis. It is not compatible with Multi-Material ALE laws, LAW37 (BIMAT) and /MAT/LAW51 (MULTIMAT). In case of turbulence, activate boundary turbulence modeling using /MAT/B-K-EPS and input κ - boundary conditions.
Block Format Keyword Describes the hydrodynamic bi-material liquid gas material. It is not recommended to use multi-material laws
with Radioss single precision engine.
Block Format Keyword Up to four material laws can be defined: elasto-plastic solid, liquid, gas and detonation products. The material law
is based on a diffusive interface technique to get sharper interfaces between submaterial zone (/ALE/MUSCL in Radioss Starter Input).
Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement
or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom
(DOF). Two kinematic conditions applied to the same node may be incompatible.
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as
pressure, gravity, and thermal load.
Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
All characters beyond
the tenth of a keyword are ignored (for example, it is possible to input
HONEYCOM, instead of HONEYCOMB).
The Manual Keyword is
the keyword of the law as referenced in this manual.
The Law Number is the
material law number used to reference the material law in the fixed format
manual.
The Other Available
Keywords column features other keywords which can be used to define the same
material laws.
In addition to the ALE
material laws, the material laws 1, 2, 3, 4 and the isotropic material laws with
volumetric properties are compatible with the ALE approach. ALE (Arbitrary
Lagrangian-Eulerian) material laws (11, 18, 20, 26, 37 and 51) are described in
the ALE options.
If a node is connected
to an ALE material, the nodal value output to /TH and
Animation files have the following description:
positions and displacements represent the grid positions and
displacements;
accelerations and velocities represent the material accelerations and
velocities.
/MAT/LAW11 (BOUND) Block Format Keyword This law describes the boundary conditions material in flow analysis (ALE or EULER). It is compatible for 2D and 3D analysis. It is not compatible with Multi-Material ALE laws, LAW37 (BIMAT) and /MAT/LAW51 (MULTIMAT). In case of turbulence, activate boundary turbulence modeling using /MAT/B-K-EPS and input κ - ˙ε boundary conditions.
/MAT/LAW18 (THERM) Block Format Keyword This law describes thermal material.
/MAT/LAW20 (BIMAT) Block Format Keyword ALE multi-material law for 2D analysis.
/MAT/LAW26 (SESAM) Block Format Keyword This ALE material law describes a SESAME tabular EOS, used with a Johnson-Cook yield criterion.
/MAT/LAW37 (BIPHAS) Block Format Keyword Describes the hydrodynamic bi-material liquid gas material. It is not recommended to use multi-material laws with Radioss single precision engine.
/MAT/LAW51 (MULTIMAT) Block Format Keyword Up to four material laws can be defined: elasto-plastic solid, liquid, gas and detonation products. The material law is based on a diffusive interface technique to get sharper interfaces between submaterial zone (/ALE/MUSCL in Radioss Starter Input).
