CFD Materials
| Manual Keyword | Law Number | Other Available Keywords |
| /MAT/K-EPS | ||
| /MAT/B-K-EPS | ||
| /MAT/LAW46 (LES_FLUID) | 46 | LAW46 |
These laws are only compatible with Radioss CFD.
- All characters beyond the tenth of a keyword are ignored (for example, it is possible to input HONEYCOM, instead of HONEYCOMB).
- The Manual Keyword is the keyword of the law as referenced in this manual.
- The Law Number is the material law number used to reference the material law in the fixed format manual.
- The Other Available Keywords column features other keywords which can be used to define the same material laws.
- Laws K-EPS and 46 are not compatible with Shell, Truss and Beam elements.
