/INITRUSS/FULL
Block Format Keyword Describes the initial state for truss elements. All values defined in this card will be applied at the beginning on the computation.
| /INITRUSS/FULL/unit_ID | |||||||||
| truss_ID | prop_type | ||||||||
| EINT | F | AREA | |||||||
Definition
| unit_ID | Optional unit
| spring_ID | Element
identifier (Integer) |
| prop_type | Property set
(Integer) |
| EINT | Total internal energy
(Real) |
| F | Truss element normal
force (Real) |
| AREA | Cross-sectional area
of the truss (Real) |
| Plastic
strain (Real) |
