1.out File Examples
The following depicts, for one same model computed with Radioss version 11.0.201, the Engine output (_0001.out) file evolution from an over-estimated to an under-estimated imposed AMS time step.
Over-Estimated /DT/AMS Target Time Step
20 Times the Reference /DT/NODA/CST
Note the progressive switch from element (SOLID) driven time step to interface (INTER) time step drop due to their spring reaction stiffness to finally end with an AMS divergence.
CYCLE   TIME       TIME-STEP ELEMENT            ERROR  I-ENERGY   K-ENERGY T  K-ENERGY R  EXT-WORK    MAS.ERR
    0   0.000     0.3980E-02 SOLID    1026400   0.0%   0.000      0.4134E+06   0.000     -0.1719E-10  0.7671E-02
    ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_MAXA001 WRITTEN
   10  0.3980E-01 0.3980E-02 SOLID    1026953   0.0%  -4.176      0.4134E+06  0.2174       22.59      0.7671E-02
   20  0.7960E-01 0.3980E-02 SOLID    1027171   0.0%   8.901      0.4135E+06  0.7490       81.41      0.7671E-02
   30  0.1194     0.3980E-02 SOLID    1027865   0.0%   43.57      0.4135E+06   1.742       164.1      0.7671E-02
   40  0.1592     0.3980E-02 SOLID    1026669   0.0%   94.41      0.4136E+06   4.155       261.0      0.7671E-02
   50  0.1990     0.3980E-02 SOLID    1026928   0.0%   158.0      0.4136E+06   9.559       364.5      0.7671E-02
   60  0.2388     0.3980E-02 SOLID    1027135   0.0%   230.8      0.4136E+06   17.50       470.2      0.7671E-02
   70  0.2786     0.3980E-02 SOLID    1027670   0.0%   303.5      0.4137E+06   27.21       574.8      0.7671E-02
   80  0.3184     0.3980E-02 SOLID    1027755   0.0%   366.8      0.4137E+06   36.79       674.5      0.7671E-02
   90  0.3582     0.3980E-02 SOLID    1027323   0.0%   419.8      0.4137E+06   42.80       767.0      0.7671E-02
  100  0.3980     0.3980E-02 SOLID    1026690   0.0%   464.3      0.4137E+06   46.51       850.7      0.7671E-02
 1100   4.378     0.3980E-02    SOLID  1027754  0.0%     2558.    0.4116E+06   61.59       1016.      0.7671E-02
 1110   4.418     0.3980E-02    SOLID  1027894  0.0%     2617.    0.4116E+06   63.80       1002.      0.7671E-02
 1120   4.457     0.3980E-02    SOLID  1026231  0.0%     2680.    0.4115E+06   63.67       990.5      0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER   7004937
 1130   4.497     0.3980E-02    SOLID  1027738  0.0%     2744.    0.4114E+06   61.73       980.9      0.7671E-02
 1140   4.537     0.3980E-02    SOLID  1027858 -0.1%   2807.      0.4113E+06   59.50       973.5      0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER   7004935
 1150   4.577     0.3980E-02    SOLID  1027880 -0.1%     2867.    0.4113E+06   58.56       968.7      0.7671E-02
 1160   4.617     0.3980E-02    SOLID  1027278 -0.1%     2926.    0.4112E+06   59.27       966.8      0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER   7004933
 1170   4.656      0.3980E-02   SOLID  1027327 -0.1%     2984.    0.4111E+06   62.11       968.2      0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER   7004931
 1180   4.696     0.3916E-02    INTER  42009748 -0.1%    3047.    0.4111E+06   66.28       973.2      0.7671E-02
 1190   4.735     0.3779E-02    INTER  42009748 -0.1%    3111.    0.4110E+06   72.50       982.0      0.7671E-02
 1200   4.772     0.3709E-02    INTER  42009748 -0.1%    3178.    0.4109E+06   80.35       994.9      0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER   7004929
 1210   4.809     0.3628E-02    INTER  42009748 -0.1%    3247.    0.4109E+06   89.95       1012.      0.7671E-02
 1220   4.845     0.3591E-02    INTER  42009748 -0.1%    3319.    0.4108E+06   98.18       1033.      0.7671E-02
 1230   4.881     0.3659E-02    INTER  42009748 -0.1%    3394.    0.4107E+06   104.3       1060.      0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER   7004927
 1240   4.917     0.3621E-02    INTER  42009748 -0.1%    3474.    0.4107E+06   108.6       1090.      0.7671E-02
 1250   4.954     0.3656E-02    INTER  42009748 -0.1%    3561.    0.4106E+06   113.7       1124.      0.7671E-02
 1260   4.990     0.3622E-02    INTER  42009748 -0.1%    3656.     0.4105E+06   117.2      1159.      0.7671E-02
     ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_MAXA002 WRITTEN
 1270   5.026     0.3631E-02    INTER  42009748 -0.1%    3760.    0.4105E+06   122.4       1194.      0.7671E-02
 1280   5.062     0.3585E-02    INTER  42009748 -0.1%    3865.    0.4104E+06   122.7       1226.      0.7671E-02
 1290   5.098     0.3567E-02    INTER  42009748 -0.1%    3972.    0.4103E+06   125.0       1255.      0.7671E-02
 1300   5.133     0.3578E-02    INTER  42009748 -0.1%    4074.    0.4102E+06   126.3       1280.      0.7671E-02
 39500  79.47     0.6686E-03    INTER   42009748 -9.4%  0.2141E+06  0.1554E+06   1465.     -4253.     0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     873536
 -- RUPTURE OF SHELL ELEMENT NUMBER     873327
 39510  79.48     0.6686E-03    INTER   42009748 -9.4%  0.2141E+06  0.1554E+06   1465.     -4254.     0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     873995
 39520  79.48     0.6685E-03    INTER   42009748 -9.4%  0.2141E+06  0.1554E+06   1466.     -4255.     0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     872733
 39530  79.49     0.6684E-03    INTER   42009748 -9.4%  0.2141E+06  0.1554E+06   1466.     -4256.     0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     876109
 -- RUPTURE OF SHELL ELEMENT NUMBER     876112
 39540  79.50     0.6684E-03    INTER   42009748 -9.4%  0.2141E+06  0.1554E+06   1467.     -4257.     0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     874081
 -- RUPTURE OF SHELL ELEMENT NUMBER     874082
 ** ERROR : AMS IS LIKELY DIVERGING:
    TOTAL C.G. ITERATION NUMBER =     1000 AT CYCLE NUMBER    39550
39550   79.50     0.6685E-03    INTER   42009748  NaN%  0.2141E+06         NaN         NaN  -4258.    0.7671E-02
                           ** CPU USER TIME **
Case: AMSmaxi_ x20 _ div 79.5stop_32cpu_14.5h_ 110201 sep30
Almost Acceptable /DT/AMS Target Time Step
13 Times the Reference /DT/NODA/CST
Note the late switch from element (SH3N and SOLID) driven time step to interface (INTER) time step drop due to their spring reaction stiffness and node (NODE) driven due to rotations whereas element translation was initially controlling the time step.
(No AMS divergence, the job successfully ended at the 37220th cycle for 100ms)
     0     0.000     0.2736E-02 SOLID    1026805    0.0%   0.000    0.4134E+06     0.000      .1719E-10    0.7671E-02
     ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_OPT1A001 WRITTEN
    10    0.2736E-01 0.2736E-02 SOLID    1026339    0.0%  -9.938    0.4134E+06     0.9492E-01     11.27    0.7671E-02
    20    0.5472E-01 0.2736E-02 SH_3N     980467    0.05% -2.140    0.4135E+06     0.2769         41.40    0.7671E-02
    30    0.8209E-01 0.2736E-02 SH_3N     983904    0.0%   12.94    0.4135E+06     0.7553         86.61    0.7671E-02
    40    0.1094     0.2736E-02 SOLID    1025858    0.0%   34.57    0.4135E+06     1.560          142.9    0.7671E-02
    50    0.1368     0.2736E-02 SOLID    1026994    0.0%   65.14    0.4136E+06     2.777          207.0    0.7671E-02
    60    0.1642     0.2736E-02 SH_3N     979591    0.0%   102.8    0.4136E+06     4.844          276.2    0.7671E-02
    70    0.1915     0.2736E-02 SH_3N    1011870    0.0%   147.1    0.4136E+06     8.051          348.0    0.7671E-02
    80    0.2189     0.2736E-02 SOLID    1027827    0.0%   197.0    0.4136E+06     12.51          421.2    0.7671E-02
    90    0.2463     0.2736E-02 SOLID    1025763    0.0%   249.5    0.4136E+06     17.97          494.7    0.7671E-02
   100    0.2736     0.2736E-02 SOLID    1026760    0.0%   300.5    0.4137E+06     24.45          567.3    0.7671E-02
-- RUPTURE OF SHELL ELEMENT NUMBER    9861056
  5500   15.04     0.2736E-02 SH_3N     980451    -1.0%  0.3598E+05  0.3741E+06    377.9         1060.    0.7671E-02
  5510   15.06     0.2736E-02 SH_3N     980451    -1.0%  0.3607E+05  0.3740E+06    379.4         1048.    0.7671E-02
  5520   15.09     0.2736E-02 SH_3N     980440    -1.0%  0.3614E+05  0.3739E+06    380.1         1035.    0.7671E-02
  5530   15.12     0.2736E-02 SH_3N     983880    -1.0%  0.3623E+05  0.3738E+06    379.8         1021.    0.7671E-02
  5540   15.15     0.2736E-02 SH_3N    1012368    -1.0%  0.3630E+05  0.3737E+06    379.0         1005.    0.7671E-02
  5550   15.17     0.2736E-02 SH_3N     980451    -1.0%  0.3638E+05  0.3736E+06    377.9         987.8    0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER    9897179
  5560   15.20     0.2736E-02 SH_3N     980112    -1.0%  0.3645E+05  0.3735E+06    377.0         969.7    0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER    9896885
  5570   15.23     0.2736E-02 SH_3N    1015803    -1.0%  0.3652E+05  0.3734E+06    376.7         950.6    0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER    9897148
  5580   15.26     0.2736E-02 SH_3N    1012363    -1.0%  0.3659E+05  0.3733E+06    377.0         930.5    0.7671E-02
  5590   15.28     0.2736E-02 SH_3N    1018445    -1.0%  0.3666E+05  0.3732E+06    377.9         909.5    0.7671E-02
  5600   15.31     0.2736E-02 SH_3N     971703    -1.0%  0.3673E+05  0.3731E+06    378.8         887.8    0.7671E-02
 18200   48.77     0.2393E-02 INTER   42009748    -6.2%  0.1561E+06   0.2282E+06   888.8         -2873.    0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER  7001813
 18210   48.79     0.2431E-02 INTER   42009748    -6.2%  0.1562E+06   0.2281E+06   889.2         -2873.    0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER  7002310
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER  7001709
 18220   48.82     0.2495E-02 INTER   42009748    -6.2%  0.1563E+06   0.2280E+06   888.3         -2872.    0.7671E-02
 18230   48.84     0.2607E-02 INTER   42009748    -6.2%  0.1564E+06   0.2279E+06   891.0         -2870.    0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER  7001821
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER  7002666
 18240   48.87     0.2668E-02 NODE    10103704    -6.2%  0.1564E+06   0.2278E+06   893.2          -2869.   0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER  7002205
 18250   48.90     0.2665E-02 NODE    10103704    -6.2%  0.1565E+06   0.2277E+06   896.1          -2867.   0.7671E-02
 18260   48.92     0.2663E-02 NODE    10103704    -6.2%  0.1566E+06   0.2276E+06   897.3          -2865.   0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER  7001710
 18270   48.95     0.2614E-02 INTER   42009748    -6.2%  0.1567E+06   0.2275E+06   897.7          -2863.   0.7671E-02
 18280   48.98     0.2599E-02 INTER   42009748    -6.2%  0.1568E+06   0.2274E+06   895.9          -2861.   0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER  7001702
 18290   49.00     0.2655E-02 NODE    10103704    -6.2%  0.1568E+06   0.2273E+06   895.6          -2860.   0.7671E-02
 18300   49.03     0.2736E-02 SH_3N     979131    -6.2%  0.1569E+06   0.2272E+06   896.7          -2859.   0.7671E-02
37100   99.69     0.2612E-02 INTER   42009748     -9.4%  0.2150E+06   0.1548E+06    1712.         -3241.    0.7671E-02
37110   99.71     0.2633E-02 INTER   42009748     -9.4%  0.2150E+06   0.1548E+06    1712.         -3239.    0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     872981
37120   99.74     0.2631E-02 INTER   42009748     -9.4%  0.2150E+06   0.1549E+06    1711.         -3237.    0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     876845
37130   99.77     0.2630E-02 INTER   42009748     -9.4%  0.2150E+06   0.1549E+06    1711.         -3235.    0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     877165
37140   99.79     0.2627E-02 INTER   42009748     -9.4%  0.2150E+06   0.1549E+06    1710.         -3233.    0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     872868
37150   99.82     0.2609E-02 INTER   42009748     -9.4%  0.2150E+06   0.1549E+06    1709.         -3231.    0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     877277
 -- RUPTURE OF SHELL ELEMENT NUMBER     877278
37160   99.84     0.2669E-02 INTER   42009748     -9.4%  0.2150E+06   0.1549E+06    1709.         -3229.    0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     877051
37170   99.87     0.2671E-02 INTER   42009748     -9.4%  0.2150E+06   0.1549E+06    1708.         -3227.    0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     876266
37180   99.90     0.2671E-02 INTER   42009748     -9.4%  0.2150E+06   0.1549E+06    1706.         -3225.    0.7671E-02
37190   99.92     0.2660E-02 INTER   42009748     -9.4%  0.2150E+06   0.1549E+06    1705.         -3224.    0.7671E-02
37200   99.95     0.2643E-02 INTER   42009748     -9.4%  0.2150E+06   0.1549E+06    1704.         -3223.    0.7671E-02
37210   99.98     0.2643E-02 INTER   42009748     -9.4%  0.2150E+06   0.1549E+06    1703.         -3222.    0.7671E-02
     ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_OPT1A021 WRITTEN
37220   100.0     0.2623E-02 INTER   42009748    -9.4%  0.2150E+06    0.1549E+06    1703.         -3221.    0.7671E-02
     RESTART FILES: DFWDS734_AMS_FULL_REWELD_NOSECT_OPT1_0001_[0001-0004].rst WRITTEN
** CPU USER TIME **
Case: AMSopt1_x13_16cpu_26h_110201sep30
12.5 Times the Reference /DT/NODA/CST
Note the essentially element (SH3N) driven time step with exceptional interface (INTER) time step influence and no node (NODE) driven time step.
(No AMS divergence, the job successfully ended at the 40230th cycle for 100ms)
    0    0.000      0.2487E-02   SH_3N    987177    0.0%     0.000   0.4134E+06  0.000    -0.1719E-10     0.7671E-02
ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_OPTA001 WRITTEN
   10  0.2487E-01  0.2487E-02    SH_3N    1004312    0.0%    -11.02  0.4134E+06  0.7503E-01   9.448       0.7671E-02
   20  0.4975E-01  0.2487E-02    SH_3N     994772    0.0%    -2.833  0.4135E+06  0.2556       34.67       0.7671E-02
   30  0.7462E-01  0.2487E-02    SH_3N     980477    0.0%     8.087  0.4135E+06  0.5928       73.10       0.7671E-02
   40  0.9950E-01  0.2487E-02    SH_3N     980465    0.0%     25.51  0.4135E+06   1.253       121.5       0.7671E-02
   50  0.1244      0.2487E-02    SH_3N     994783    0.0%     50.64  0.4135E+06   2.161       177.3       0.7671E-02
   60  0.1492      0.2487E-02    SH_3N     983873    0.0%     81.66  0.4136E+06   3.542       238.2       0.7671E-02
   70  0.1741      0.2487E-02    SH_3N     983929    0.0%     118.5  0.4136E+06   5.751       302.3       0.7671E-02
   80  0.1990      0.2487E-02    SH_3N     980233    0.0%     160.6  0.4136E+06   9.149       368.2       0.7671E-02
   90  0.2239      0.2487E-02    SH_3N     980624    0.0%     206.9  0.4136E+06   13.47       434.9       0.7671E-02
  100  0.2487      0.2487E-02    SH_3N     985772    0.0%     254.8  0.4136E+06   18.63       501.6       0.7671E-02
 4980   12.39      0.2487E-02    SH_3N     983878   -0.7%  0.2624E+05  0.3855E+06  319.2       1427.      0.7671E-02
 4990   12.41      0.2487E-02    SH_3N     983854   -0.7%  0.2633E+05  0.3854E+06  317.9       1422.      0.7671E-02
 5000   12.44      0.2487E-02    SH_3N     980375   -0.7%  0.2642E+05  0.3852E+06  317.3       1416.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     9897228
  5010   12.46     0.2487E-02    SH_3N     986833   -0.7%  0.2651E+05  0.3851E+06  317.1       1409.      0.7671E-02
  5020   12.49     0.2487E-02    SH_3N     980402   -0.7%  0.2660E+05  0.3850E+06  316.0       1402.      0.7671E-02
  5030   12.51     0.2487E-02    SH_3N     978799   -0.7%  0.2669E+05  0.3849E+06  316.4       1393.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     9897051
  5040   12.54     0.2440E-02    INTER   42009748   -0.7%  0.2679E+05  0.3848E+06  316.3       1384.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     9897049
  5050   12.56     0.2473E-02    INTER   42009748   -0.7%  0.2687E+05  0.3847E+06  316.3       1375.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     9897202
 -- RUPTURE OF SHELL ELEMENT NUMBER     9897044
  5060   12.59     0.2487E-02    SH_3N   985187     -0.7%  0.2696E+05  0.3846E+06  317.1       1364.      0.7671E-02
  5070   12.61     0.2487E-02    SH_3N   983885     -0.7%  0.2705E+05  0.3845E+06  318.2       1353.      0.7671E-02
  5080   12.64     0.2487E-02    SH_3N   980507     -0.7%  0.2713E+05  0.3844E+06  319.4       1342.      0.7671E-02
 40000   99.43     0.2487E-02    SH_3N   983740     -6.5%  0.2268E+06  0.1548E+06  1688.      -3544.      0.7671E-02
 40010   99.46     0.2487E-02    SH_3N   981895     -6.5%  0.2268E+06  0.1548E+06  1691.      -3540.      0.7671E-02
 40020   99.48     0.2487E-02    SH_3N   984028     -6.5%  0.2268E+06  0.1548E+06  1694.      -3536.      0.7671E-02
 40030   99.51     0.2487E-02    SH_3N   982888     -6.5%  0.2268E+06  0.1549E+06  1697.      -3532.      0.7671E-02
 40040   99.53     0.2487E-02    SH_3N   993482     -6.5%  0.2268E+06  0.1549E+06  1700.      -3528.      0.7671E-02
 40050   99.55     0.2487E-02    SH_3N  1002607     -6.5%  0.2268E+06  0.1549E+06  1703.      -3525.      0.7671E-02
 40060   99.58     0.2487E-02    SH_3N   986010     -6.5%  0.2268E+06  0.1549E+06  1706.      -3521.      0.7671E-02
 40070   99.60     0.2487E-02    SH_3N   981287     -6.5%  0.2268E+06  0.1549E+06  1708.      -3518.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER      876247
 40080   99.63     0.2487E-02    SH_3N   993747     -6.5%  0.2268E+06  0.1549E+06  1711.      -3515.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER      876267
 40090   99.65     0.2487E-02    SH_3N   969592     -6.5%  0.2268E+06  0.1549E+06  1712.      -3512.      0.7671E-02
 40100   99.68     0.2487E-02    SH_3N   985183     -6.5%  0.2268E+06  0.1549E+06  1713.      -3510.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER      876245
 40110   99.70     0.2487E-02    SH_3N   979126     -6.5%  0.2268E+06  0.1549E+06  1710.      -3507.      0.7671E-02
 40120   99.73     0.2487E-02    SH_3N   981287     -6.4%  0.2269E+06  0.1549E+06  1705.      -3504.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER      876374
 40130   99.75     0.2487E-02    SH_3N   985787      -6.4%  0.2269E+06  0.1549E+06  1699.     -3501.      0.7671E-02
 40140   99.78     0.2487E-02    SH_3N   981843      -6.4%  0.2269E+06  0.1549E+06  1694.     -3498.      0.7671E-02
 40150   99.80     0.2487E-02    SH_3N   986153      -6.4%  0.2269E+06  0.1549E+06  1691.     -3495.      0.7671E-02
 40160   99.83     0.2487E-02    SH_3N   993115      -6.4%  0.2269E+06  0.1549E+06  1689.     -3492.      0.7671E-02
 40170   99.85     0.2487E-02    SH_3N   995959      -6.4%  0.2269E+06  0.1549E+06  1688.     -3490.      0.7671E-02
 40180   99.88     0.2487E-02    SH_3N   979140      -6.4%  0.2269E+06  0.1549E+06  1688.     -3487.      0.7671E-02
 40190   99.90     0.2487E-02    SH_3N   985244      -6.4%  0.2269E+06  0.1549E+06  1689.     -3485.      0.7671E-02
 40200   99.93     0.2487E-02    SH_3N   993949      -6.4%  0.2269E+06  0.1549E+06  1691.     -3483.      0.7671E-02
 40210   99.95     0.2487E-02    SH_3N   988714      -6.4%  0.2269E+06  0.1550E+06  1694.     -3481.      0.7671E-02
 40220   99.98     0.2487E-02    SH_3N   986153      -6.4%  0.2269E+06  0.1550E+06  1697.     -3479.      0.7671E-02
     ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECT_OPTA021 WRITTEN
40230   100.0      0.2487E-02    SH_3N   980714      -6.4%  0.2269E+06  0.1550E+06  1698.     -3477.      0.7671E-02
     RESTART FILES: DFWDS734_AMS_FULL_REWELD_NOSECT_OPT_0001_[0001-0004].rst WRITTEN
 ** CPU USER TIME **
Case: AMSopt_x12.5_32cpu_17.8h_110201sep30
Under-estimated /DT/AMS Target Time Step
10 Times the Reference /DT/NODA/CST
Note the uniquely element (SH3N) driven time step. No interface (INTER) or node (NODE) driven time step (the job successfully ended at the 50250th cycle for 100ms)
    0   0.000     0.1990E-02 SOLID    1026809   0.0%      0.000   0.4134E+06  0.000     -0.1719E-10   0.7671E-02
     ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECTA001 WRITTEN
   10  0.1990E-01 0.1990E-02 SOLID    1027233   0.0%     -12.55   0.4134E+06  0.4509E-01   6.263      0.7671E-02
   20  0.3980E-01 0.1990E-02 SOLID    1026793   0.0%     -3.404   0.4134E+06  0.1923       22.77      0.7671E-02
   30  0.5970E-01 0.1990E-02 SOLID    1026919   0.0%    -0.3391   0.4135E+06  0.3412       48.73      0.7671E-02
   40  0.7960E-01 0.1990E-02 SOLID    1026987   0.0%      11.02   0.4135E+06  0.7014       82.15      0.7671E-02
   50  0.9950E-01 0.1990E-02 SOLID    1027291   0.0%      25.55   0.4135E+06   1.259       121.6      0.7671E-02
   60  0.1194     0.1990E-02 SOLID    1026789   0.0%      45.07   0.4135E+06   1.935       165.8      0.7671E-02
   70  0.1393     0.1990E-02 SOLID    1026910   0.0%      68.49   0.4136E+06   2.833       213.5      0.7671E-02
   80  0.1592     0.1990E-02 SOLID    1027497   0.0%      95.78   0.4136E+06   4.219       263.7      0.7671E-02
   90  0.1791     0.1990E-02 SOLID    1027432   0.0%      126.7   0.4136E+06   6.282       315.5      0.7671E-02
  100  0.1990     0.1990E-02 SOLID    1027197   0.0%      160.8   0.4136E+06   9.184       368.2      0.7671E-02
  6220   12.38     0.1990E-02 SOLID    1027341  -0.6%  0.2623E+05  0.3856E+06   304.8       1425.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER    9897042
  6230   12.40     0.1990E-02 SOLID    1026467  -0.6%  0.2630E+05  0.3856E+06   304.8       1422.      0.7671E-02
  6240   12.42     0.1990E-02 SOLID    1027168  -0.7%  0.2637E+05  0.3855E+06   303.9       1418.      0.7671E-02
  6250   12.44     0.1990E-02 SOLID    1026994  -0.7%  0.2645E+05  0.3854E+06   303.5       1413.      0.7671E-02
  6260   12.46     0.1990E-02 SOLID    1026918  -0.7%  0.2652E+05  0.3853E+06   302.8       1408.      0.7671E-02
  6270   12.48     0.1990E-02 SOLID    1027344  -0.7%  0.2659E+05  0.3852E+06   301.9       1402.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER    9897040
  6280   12.50     0.1990E-02 SOLID    1027487  -0.7%  0.2667E+05  0.3851E+06   300.8       1395.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER    9897152
  6290   12.52     0.1990E-02 SOLID    1027341  -0.7%  0.2674E+05  0.3850E+06   300.0       1388.      0.7671E-02
  6300   12.54     0.1990E-02 SOLID    1027156  -0.7%  0.2681E+05  0.3849E+06   299.5       1381.      0.7671E-02
  6310   12.56     0.1990E-02 SOLID    1027292  -0.7%  0.2688E+05  0.3849E+06   299.1       1372.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER    9897037
  6320   12.58     0.1990E-02 SOLID    1026512  -0.7%  0.2696E+05  0.3848E+06   299.1       1364.      0.7671E-02
 -- CONSTANT TIME STEP FOR SOLID ELEMENT NUMBER  7004883
  6330   12.60     0.1990E-02 SOLID    1027473  -0.7%  0.2702E+05  0.3847E+06   299.6       1355.      0.7671E-02
  6340   12.62     0.1990E-02 SOLID    1027340  -0.7%  0.2709E+05  0.3846E+06   300.6       1346.      0.7671E-02
  6350   12.64     0.1990E-02 SOLID    1027345  -0.7%  0.2716E+05  0.3845E+06   301.1       1337.      0.7671E-02
 49970   99.44     0.1990E-02 SOLID    1026732  -7.5%  0.2226E+06  0.1550E+06   1683.      -3546.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     878377
 49980   99.46     0.1990E-02 SOLID    1027394  -7.5%  0.2226E+06  0.1550E+06   1683.      -3543.      0.7671E-02
 49990   99.48     0.1990E-02 SOLID    1026474  -7.5%  0.2226E+06  0.1550E+06   1683.      -3541.      0.7671E-02
 50000   99.50     0.1990E-02 SOLID    1026918  -7.5%  0.2226E+06  0.1550E+06   1683.      -3538.      0.7671E-02
 50010   99.52     0.1990E-02 SOLID    1026842  -7.5%  0.2226E+06  0.1550E+06   1684.      -3536.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     877707
 50020   99.54     0.1990E-02 SOLID    1026846  -7.5%  0.2226E+06  0.1550E+06   1684.      -3533.      0.7671E-02
 50030   99.56     0.1990E-02 SOLID    1026916  -7.5%  0.2226E+06  0.1550E+06   1685.      -3531.      0.7671E-02
 50040   99.58     0.1990E-02 SOLID    1026846  -7.5%  0.2226E+06  0.1550E+06   1686.      -3529.      0.7671E-02
 50050   99.60     0.1990E-02 SHELL     389951  -7.4%  0.2226E+06  0.1550E+06   1686.      -3526.      0.7671E-02
 50060   99.62     0.1990E-02 SOLID    1026916  -7.4%  0.2226E+06  0.1550E+06   1686.      -3524.      0.7671E-02
 50070   99.64     0.1990E-02 SOLID    1027698  -7.4%  0.2226E+06  0.1551E+06   1687.      -3522.      0.7671E-02
 50080   99.66     0.1990E-02 SHELL     389982  -7.4%  0.2227E+06  0.1551E+06   1687.      -3520.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     877600
 50090   99.68     0.1990E-02 SHELL     390246  -7.4%  0.2227E+06  0.1551E+06   1688.      -3518.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     872853
 50100   99.70     0.1990E-02 SOLID    1026474  -7.4%  0.2227E+06  0.1551E+06   1688.      -3515.      0.7671E-02
 50110   99.72     0.1990E-02 SOLID    1026911  -7.4%  0.2227E+06  0.1551E+06   1689.      -3513.      0.7671E-02
 50120   99.74     0.1990E-02 SOLID    1026914  -7.4%  0.2227E+06  0.1551E+06   1689.      -3511.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     877814
 50130   99.76     0.1990E-02 SOLID    1026500  -7.4%  0.2227E+06  0.1551E+06   1690.      -3508.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     875485
 50140   99.78     0.1990E-02 SOLID    1027163  -7.4%  0.2227E+06  0.1551E+06   1690.      -3506.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     880641
 50150   99.80     0.1990E-02 SOLID    1026107  -7.4%  0.2227E+06  0.1551E+06   1690.      -3504.      0.7671E-02
 50160   99.82     0.1990E-02 SOLID    1027004  -7.4%  0.2227E+06  0.1551E+06   1691.      -3501.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     877598
 50170   99.84     0.1990E-02 SOLID    1026998  -7.4%  0.2227E+06  0.1551E+06   1690.      -3499.      0.7671E-02
 50180   99.86     0.1990E-02 SHELL     390073  -7.4%  0.2227E+06  0.1551E+06   1690.      -3497.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     877149
 50190   99.88     0.1990E-02 SHELL     254450  -7.4%  0.2227E+06  0.1551E+06   1690.      -3495.      0.7671E-02
 50200   99.90     0.1990E-02 SOLID    1026757  -7.4%  0.2227E+06  0.1551E+06   1690.      -3493.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     880538
 50210   99.92     0.1990E-02 SOLID    1026603  -7.4%  0.2227E+06  0.1551E+06   1690.      -3491.      0.7671E-02
 50220   99.94     0.1990E-02 SOLID    1027433  -7.4%  0.2227E+06  0.1551E+06   1690.      -3489.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     877599
 50230   99.96     0.1990E-02 SOLID    1026799  -7.4%  0.2227E+06  0.1551E+06   1690.      -3488.      0.7671E-02
 50240   99.98     0.1990E-02 SOLID    1027571  -7.4%  0.2227E+06  0.1551E+06   1690.      -3486.      0.7671E-02
 50250   100.0     0.1990E-02 SOLID    1027536  -7.4%  0.2227E+06  0.1552E+06   1690.      -3485.      0.7671E-02
 -- RUPTURE OF SHELL ELEMENT NUMBER     872739
     ANIMATION FILE: DFWDS734_AMS_FULL_REWELD_NOSECTA021 WRITTEN
 -- RUPTURE OF SHELL ELEMENT NUMBER     872967
     RESTART FILES: DFWDS734_AMS_FULL_REWELD_NOSECT_0001_[0001-0004].rst WRITTEN
                           ** CPU USER TIME **
Case: AMSnorm_x10_16cpu_33.7h_110201sep30
