Overview
Read a high-level overview of Inspire Fluids with usage notes directly from the Fluids product team.
What is Inspire Fluids?
Inspire Fluids is a design exploration tool that can be used to rapidly evaluate the characteristics of fluids and thermal systems. It provides upfront CFD capabilities for product design with simplified pre-processing and post-processing workflows.
- Is fast, robust, and delivers dependable CFD results with optimized accuracy
- Allows you to explore and enhance fluid and thermal designs with an intuitive and user-friendly interface
- Is ideal for both beginners and experts
- Uses the power of state-of-the-art CPU and GPU-based solver technology to investigate design with minimal effort
- Steady-state, single-phase
- Laminar and turbulent flow
- Heat transfer in fluids and solids
- Essential boundary conditions (inlets, outlets, walls)
- Easily assess fluid and thermal behavior early in designs for faster, more informed product design cycles
- Create and modify the shape of parts or assemblies to meet thermal and hydraulic objectives
- Work directly on the geometry with the help of Inspire’s parametric
engineNote: Traditional CFD meshing is not required.
- Compute pressure drops, and process efficiencies and temperature fields early in the design cycle without waiting for a detailed analysis on finalized geometry
- Ensure thermal margin, acceptable energy input requirements, and acceptable stress levels
- Identify flow patterns, jets, and recirculation regions using streamlines, vectors, isocontours, and section-cuts
- Visualize pressure, velocity, and temperature fields
- Predict flow velocity, uniformity, and flow fraction at model outlets
- Predict bulk fluid and wall temperatures
- Estimate forces on walls
Inspire Fluids Core Technology:
- Finite-volume, immersed boundary methods
- Turbulence wall functions
- NVIDIA GPU support
- Multi-threaded CPU support
