Altair Inspire User Guide
2023
  1. Home
  2. Fluids
    Prepare and run a computational fluid dynamics simulation.
  3. Troubleshooting
    Need help troubleshooting a problem in Inspire Fluids? Check out our troubleshooting topics.
  • What's New
  • Get Started
  • Tutorials
  • Parametric Modeling
  • Implicit Modeling
  • Structures
  • Motion
  • Fluids
  • Design Explorer
  • Manufacture
  • Print 3D
  • Rendering
  • Inspire Python API
  • Reference
  • Keyboard Shortcuts and Mouse Controls
Index
2023
  • What's New
    Discover new features and enhancements.
  • Get Started
    New to Inspire? Learn the basics here.
  • Tutorials
    Start using Inspire with our interactive tutorials.
    Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
  • Implicit Modeling
    Create implicit models with primitives, lattices, point clouds, fields, offsetting, Booleans, inverting, smoothing, morphing, and filleting.
  • Structures
    Set up your model and run a structural analysis or optimization.
  • Motion
    Set up and run a motion analysis, plot the results, and export the results.
  • Fluids
    • Overview
      Read a high-level overview of Inspire Fluids with usage notes directly from the Fluids product team.
    • System Requirements: Inspire Fluids
      The minimum system requirements to run Inspire Fluids are listed below.
    • Materials and Libraries
      Create materials, assign materials to parts, and organize them into libraries.
    • Domain
      Define the solid and fluid domains for the Fluids simulation.
    • Conditions
      Include at least one inlet and one outlet, and define the fluid and thermal boundary conditions.
    • Run
      Run and review the results of a Fluids analysis.
    • Best Practices
      Read workflow tips and usage recommendations from the Fluids product team to help improve your simulation results.
    • Troubleshooting
      • Unable to Extract Desired Fluid Volume
      • GPU Out of Memory
      • Engineering Quantities Plots are Empty After Successfully Completed Run
      • Simulation Terminated Before Engineering Quantities Converge
      • Default Streamlines Generated from Inlet Not Visible in Certain Regions
      • Simulation Did Not Run: Unknown Error
      • Simulation Does Not Stop
  • Design Explorer
    Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We recommend fully constraining your sketch when sketch variables are used in the design exploration.
  • Manufacture
    Set up and run a basic porosity or thinning analysis.
  • Print 3D
    Prepare and run an additive manufacturing simulation, and export a file for 3D printing.
  • Rendering
    Adjust the materials and environment of objects in the scene to create a photorealistic image.
    Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
  • Reference
    View the glossary, frequently asked questions, and errors and alerts.
    Learn keyboard shortcuts and mouse controls for common operations.
2023
  1. Home
  2. Fluids
  3. Troubleshooting
  • What's New
  • Get Started
  • Tutorials
  • Implicit Modeling
  • Structures
  • Motion
  • Fluids
  • Design Explorer
  • Manufacture
  • Print 3D
  • Rendering
  • Reference
Index
Troubleshooting
  • GPU Out of Memory
© 2024 Altair Engineering, Inc. All Rights Reserved.
