Align the x-, y-, or z-axis of the Move tool to a point, an edge, or a
face.
Select the Move tool, or press
M or T.
![](../../../images/icons/inspire/icon_move.png)
Select one or more parts and entities.
Double-click one of the graphic manipulators to enter editing mode.
Select the tip of the X, Y, or Z arrow on the Move tool.
An axis line appears.
Choose from the following options:
To |
Do this |
Align the axis to a point |
Select the point. |
Align the axis so it is parallel to an edge |
Select the edge. |
Align the axis so it is perpendicular to a face |
Select the face. |
Align the axis so it is parallel to a hole. |
Select the face of the hole. |
Right-click to exit editing mode.
Right-click and mouse through the check mark to exit, or double-right-click.
