Inspire is a concept design tool, which you can use to run structural optimization, finite element analysis, motion analysis,
and additive manufacturing analysis.
Some ribbon tabs are associated with license features. Depending upon the tab you have invoked, additional units may
be drawn. These features will be checked out for the duration of the session.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
Select a curved arrow, and then enter an angle in the microdialog.
Select a curved arrow, and then drag the object.
Tip: Grab and release parts by their snap points (end points,
midpoints, center points, etc.) to align them precisely. You can temporarily
disable snapping by holding down the Alt key.
Right-click and mouse through the check mark to exit, or double-right-click.
