Rendering Process Overview
An overview of the typical rendering process.
The Rendering environment helps you to visualize models and simulations in a realistic manner, and better illustrate your models, concepts, and data. The library provides a large selection of drag and drop materials and environments so you can quickly apply them to your models. You can also create custom materials and save them.
- Performance Render gives the best rendered performance and is best used for viewing animated simulation data.
- Quality Render provides the most realistic representation of a model and is best used for static images and final presentations.
An example of a final rendering is shown below:
