FPC Dummy Pad
Check the specification for Flexible Printed Circuit (FPC) connector pads.
FPC connector is the components in FPCB to connect PCBs.
- FPC Component Definition: Define the FPC connector component.
- FPC Component Selection: Select component from the component group list.
- Checking: Check FPC dummy pad distance and number of distances in each
side.
Figure 1.- Distance between Dummy Pad’s Edges: Set the distance value between dummy pads. If distance is not matching with the given value, PollEx DFM defines them as fails.
- Minimum Number of Dummy Pad in each Side: Set the minimum number of side dummy pads.
