Test No. VS08 Find the maximum stress of a plate with a
hole.
Definition
Due to symmetry, only ¼ section was analyzed (Figure 1).
The units are SI.
Sliding constraints applied to the left, back, and bottom faces.
The load is 5000N applied to the right face.*
The model parameters are:
- Parameters
- Value
- L
- 100mm
- H
- 50mm
- R
- 20mm
- F
- 100N/mm2
- Thickness
- 1mm
The material properties are:
- Properties
- Value
- Modulus of Elasticity
- 2.1e+11
- Poisson's Ratio
- 0.3
Results
The reference solution is given by:
(1)
With k = 3.
The following table summarizes the maximum stress.
Theory |
SimSolid |
% Difference |
| Maximum Stress [MPa] |
3.7270E+02 |
3.7775E+02 |
1.35% |
*To determine the load: 100N/mm2 x 50mm x 1mm.
