SS-V: 1090 Stepped Shaft with Fillet
Test No. VS10 Find the stress concentration in a filleted notch.
Definition
The large shaft face is fixed.
The load is 1MPa external pressure on the smaller shaft face. Run analysis with 5 adaptive passes and "Adapt to features" on.
The units are SI.
- Parameters
- Value
- D
- 120 mm
- d
- 60 mm
- r
- 3 mm
- D/d
- 2
- r/d
- 0.05
Results
| Theory | SimSolid | % Difference | |
| SZ Stress [MPa] | 2.6000E+00 | 2.4460E+00 | -5.92% |
