Altair HyperMesh
Enhancements
Constraints
The weight factor on *COUPLING and *DISTRIBUTING in the constraint entity has been removed and moved to *SURFACE, TYPE=NODE in the set entity. With this change, the attribute has been moved to the correct location.
