BAR_CHART
Bar chart of specified quantities.
BAR_CHART(“name”) { parameters}
Qualifier
User-given name
- name (string)
- User-given name of the command. The instance of a given command is referenced using this parameter.
- data_source (enum)
- Options: file, ufx_coefficients_file
- data_file (string)
- Path to location of data source file
- num_header_rows (integer)
- Number of header rows to ignore before reading in data
- output_step (integer)
- Data step to use for plot
- target_names (string)
- List of part names from which you want to extract results
- max_result_count (integer)
- Maximum number of data points to include
- name_column (integer)
- Column number which contains the names
- data_column (integer)
- Column number which contains the values
- x_label (string)
- Label for the x-axis
- y_label (string)
- Label for the y-axis
- title (string)
- Title for the plot
- show_legend (boolean)
- Show the legend or not
- legend_labels (boolean)
- Labels for use in the legend
- show_grid (boolean)
- Show grid in plot area
- active_flag (boolean)
- Read and process the command or ignore it
BAR_CHART("Cd bar chart - file"){
    data_source                = "file"
    data_file                  = "barChartData/barChartTest.txt"
    num_header_rows            = 0
    name_column                = 1
    data_column                = 2
    output_step                = 0
    y_label                    = "C_d"
    show_grid                  = off
