CUT_PLANE
Visualization surface along x, y or z.
CUT_PLANE(“name”) { parameters}
Qualifier
User-given name
- normal_direction (enum)
- Used when seed_type=rectangular
- cut_location (real)
- Location of cut along the specified axis
- x_min (real)
- Minimum extent of the plane in x
- x_max (real)
- Maximum extent of the plane in x
- y_min (real)
- Minimum extent of the plane in y
- y_max (real)
- Maximum extent of the plane in y
- z_min (real)
- Minimum extent of the plane in z
- z_max (real)
- Maximum extent of the plane in z
- name (string)
- User-given name of the command. The instance of a given command is referenced using this parameter.
- display_type (enum)
- Specify how to display the surface
- solid_display_type (enum)
- Specify the shading type for the surface. Used with display_type=solid
- mesh_line_display (boolean)
- Flag to control display of the mesh lines
- transparency (real)
- Level of transparency
- constant_color (enum)
- Color to use for the display of the cut plane. Used with color_type=constant.
- contour_function (string)
- Scalar quantity to be displayed on cut plane (pressure, velocity, and so on). Used with color_type=contour.
- line_thickness (enum)
- Thickness of lines for mesh display and feature line display
- contour_line_display (boolean)
- Display lines on the contour
- contour_line_display_type (enum)
- Line display type of contour lines
- num_contours (integer)
- Number of contour lines to be displayed in legend
- color_type (enum)
- Method used to set the display color
- active_flag (boolean)
- Read and process the command or ignore it
- legend_display (boolean)
- Flag to toggle on or off the visibility of the legend
- num_labels (integer)
- Number of labels used in legend
- legend_min (real)
- Minimum value in legend
- legend_max (real)
- Maximum value in legend
- legend_orientation (enum)
- Specify orientation of the legend
- legend_location (enum)
- Location of the legend on the image
- threshold_clipping (boolean)
- Specify if the cut plane should be clipped by the specified threshold
- threshold_function (string)
- Function to be used as threshold
- threshold_min (real)
- Minimum threshold value
- threshold_max (real)
- Maximum threshold value
- colormap_name (enum)
- Colormap name to use for displaying the scalar function values
- log_scale (boolean)
- When selected, the scalar will be colored using a logarithmic scale instead of a standard scale.
CUT_PLANE("z cut"){
     normal_direction          = z
     cut_location              = 0.0
     display_type              = solid
     solid_display_type        = smooth
     color_type                = contour
     contour_function          = "x-velocity"
     contour_line_display      = off
     contour_line_display_type = "constant"
     mesh_line_display         = off
     constant_color            = black
     line_thickness            = medium
     legend_display            = on
     legend_use_local          = on
     legend_min                = -100
     legend_max                = 100
     num_labels                = 5
     num_decimal_places        = 5
     threshold_clipping        = off
     threshold_function        = "x-velocity"
     threshold_min             = .8
     threshold_max             = 1000
