Define Mesh Controls
Use the Mesh dialog to define mesh settings.
                From the Setup ribbon, click the
                        Advanced meshing parameters tool.
 Figure 1.The Mesh dialog opens.
                In the Mesh dialog, define the desired mesh controls settings.
                - Triangle plinth
- Create a plinth surface around single voxel gaps near the wind tunnel ground.
- Triangle splitting
- Activate triangle splitting of surfaces.
- If Triangle splitting is enabled, the following edge length controls apply:- Maximum relative edge length
- Triangle edge length relative to the local voxel size.
- Maximum absolute edge length
- Maximum triangle edge length.
- Far field element size
- Coarsest element size.
- Refinement level transition layers
- Minimum number of elements to create between mesh refinement zones.
- Click Close.
