Constraints
Constraints need to be satisfied for an optimization to be acceptable. Constraints may also be associated with a DOE. While not used in the evaluation of the DOE, constraints can be useful while visualizing DOE results. Limits on displacement or stress are common examples.
Constraint Categories
- Inequality Constraint
- One sided condition that must be satisfied.
- Equality Constraint
- Precise condition that must be satisfied.
- Side Constraint
- Bounds on the input variables that limit the region of search for the
                                optimum.
Constraint Types
- Deterministic
- Deterministic constraints enable you to manually define a Bound Type, Bound Value, and evaluation source for the output response(s).
- Random
- Random problem formulations take into account the variability in the design and study the corresponding variability in the performances. This aspect is studied under reliability and robustness.
Standard Constraint Enforcement
- Standard Enforcement
- Constraints are considered feasible when they are within a small percentage of difference between their bounds. This type of enforcement is conventional.
- Strict Enforcement
- Constraints must be perfectly satisfied with no margin. This type of enforcement may require additional iterations from an optimizer for convergence.
- Percent of Constraint Bound
- Constraints must be violated by more than this value in the converged design. Strict enforcement only uses this tolerance for equality constraints.
- When the Constraint Bound = 0.0
- In general, constraint values are normalized to their bound value. One exception is if the absolute bound value is less than this parameter.
