A resource file establishes the basis of the connection to HyperStudy. Information about the input variables and/or output
        responses are passed through the file.
        If you are defining an Interanl Math
            model, dragged-and-dropped a model file into the application, or invoked HyperStudy from another application, you will not be required to manually
            load a resource file.
                In the Define Models step, Resource column of the model you are defining, click
                In the HyperStudy - Load model resource dialog, navigate
                    to your working directory and open the resource file.
                    Note: If you load a file for a Parameterized File
                        model that does not contain parameters, a dialog will appear asking if you
                        would like to parameterize the file. If you select
                            Yes, the file will open in the
                            Editor as a *.tpl file. When
                        you close the Editor, HyperStudy
                        automatically loads the*.tpl in the Resource column,
                        and inserts the file name in the Solver input file column.
