Select the solver execution script you would like HyperStudy to use
        when executing the model.
        A set of default solver codes are registered in
                HyperStudy. You will need to register solver scripts if the solver
            is not a suite solver and hence is not registered by default, or in cases where you need
            to perform a series of actions such as copying files, running one or more solvers, and
            extracting data.
                In the Define Models step, Solver Execution Script column of the model you are
                    defining, select a solver script.
